my banshee draggs
I just changed my clutches on my 02 banshee and it still dragging like im not getting all my pull what could it be?
Did you replace the cable, may be stretched.
Clutches usually drag due to notching in the clutch basket check there first then cable or misadjustment
Sounds like you got the two washers on the inside and outside of the clutch basket switched. Flip those back around and you should be good. Check out the link in my signature!
