What's needed for a complete blaster engine rebuild
Got a yamaha blaster but the engine is seized what all do I need to fix I mean everything needed crank piston connecting rod anything else also what would the price work out around thanks in advance and this forum is awesome answers to any question and the answers are all right so far thanks
What is siezed. The piston or a crank bearing or what? First thing to do is tear it down and look at the gears and bearing and so forth hard to tell without knowing why its seized
The 2 stroke bottle/tank failed causing it to sieze
Well you will need to replace crank, rod, piston and pin, bearings and seals, will need a full gasket set, oil injection block off kit and start pre mixing your gas. We mix 32 to 1. Good luck
thats why we always disable the oil injecter, sometimes you can hear it when it fails. But i just go to the trouble to mix it myself..
| All times are GMT -5. The time now is 01:46 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
