Blaster will not run please help
Old 08-05-2013, 06:51 PM
Havick's Avatar
Default Blaster will not run please help
Ok so my blaster was running great yesterday then this morning when I started it It ran for about 4 min then let out a cough and stalled now it will not start it seems like I still have compression and I have spark and gas it wants to start but let's out a little backfire and smoke comes out from air box can anyone help me out with this
Old 08-06-2013, 11:30 AM
Doctorturbo's Avatar
GOT BOOST!
Check the keyway and see if you sheared the key.
Old 08-07-2013, 12:52 PM
Havick's Avatar
Ok key is ok the flywheel is tight it started up this morning for about 2 min then died AGIAN then it would idle but when you give it gas it dies now it will not start at all
Old 08-07-2013, 12:55 PM
Havick's Avatar
I tried to unplug the tors plug at the carb still will not start does anyone know if you can just unplug tors system at the carb or do you have to take the whole system out
Old 08-07-2013, 01:37 PM
Havick's Avatar
Ok I just had it running for about 3 min then when I gave is some gas the carb caught and it died does anyone have any ideas ?
Old 08-07-2013, 01:38 PM
Havick's Avatar
Coughed. Sorry spell check
Old 08-07-2013, 06:58 PM
GOT BOOST!
Could be a lot of things but I would check venting and fuel flow issues first.
Old 08-07-2013, 08:05 PM
Havick's Avatar
Checked the reeds one fell off in my hand so I orderd a new set I HOPE THIS IS THE PROBLEM I will let you know when I install new reeds
Old 08-11-2013, 02:46 PM
Havick's Avatar
Ok put new reeds in and my blaster is running great THANKS FOR ALL HELP !!!!!!!!
Old 08-11-2013, 03:17 PM
GOT BOOST!
Good job man!!! Way to go! Now take it out and get it dirty!
Quick Reply: Blaster will not run please help
