bogging problem
I got a 99 warrior that starts n idles but once u hit the throttle it bogs n dies unless u let the throttle go? Then as it was cranking over n trying to start there's a pinging noise but it only does it when trying to start it? Some advice would be great on where to begin
I would start with the parking brake sensor at the clutch perch.
bogging warrior
Can I just eliminate the parking brake
Yes, they are junk anyway. Just permenantly connect the 2 wires at the clutch perch sensor, and get a parking brake block-off plate for about $14. They're all about the same but I lke Lonestar stuff lsracing.com
bogging n dies
I looked at it today on the clutch perch assembly there was only the wire going to the bottom n I accidentally broke the plastic housing. I got it to start and idle but still bogs n ddis when I touch the throttle. Also as I'm hitting the electric start it turns over but pings n class n almost sounds like a grinding screeching sound.. would this be a starter clutch wheel issue??? By the way thank you for the help
