1988 yamaha big bear 350 only one wheel is spinning
Only one wheel Is spinning on my quad I can still drive it both rear wheels are supposed to spin but while driving the left wheel suddenly stopped spinning and just rolls please help is it expensive to fix?
Only one wheel Is spinning on my quad I can still drive it both rear wheels are supposed to spin but while driving the left wheel suddenly stopped spinning and just rolls please help it is shaft driven (no chain) is it expensive to fix?
Bernhard
Thanks a lot where can I get the hub?
eBay perhaps.
Check if the splines on the shaft are OK, there is no point fitting a new hub if the shaft is shot.
You may get lucky. The hubs are made of a softer alloy then the steel rear axle so the spline on the hub should wear out long before the spline on the axle.
When you take the hub off you will find out soon enough. |
Bernhard
Thanks a lot
