ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Yamaha (https://atvconnection.com/forums/yamaha/)
-   -   HELP! 2006 Kodiak Won't Turn Over? Not The Relay. (https://atvconnection.com/forums/yamaha/369798-help-2006-kodiak-wont-turn-over-not-relay.html)
conorobkid Nov 12, 2016 11:45 AM
Hi All,
So, I replaced a battery and a starter relay on my Kodiak. When I turn the key there is power(display, lights etc.) However, when I press the starter button, nothing- no clicking- nothing.
When I jump the relay it turns over, however. It can't be the relay as it was the exact same before I replaced it. Any suggestions? I have a voltmeter, also.
merryman Nov 13, 2016 03:47 AM
Most obvious is a faulty button on the handlebars. Not sure if the Kodiak has a live feed to the start switch or if the switch earths the solenoid, but either way, with ignition on, you should get a voltage across the switch when you press the button.
conorobkid Nov 21, 2016 08:40 AM
Ok I'll test the starter when I'm home, thanks for the reply!
© 2026 MH Sub I, LLC dba Internet Brands
