91 warrior 350 not firing
I bought this the way it is guy said he took the fenders off to paint at this point it still ran he put everything back on it and was not getting any fire i got it put new cdi coil stator and solenoid on it and changed the kill switch and it still not firing any help on this please
the battery could be dead. is the spark plug getting spark? jets could be clogged up. could not be getting gas those are the main things you should check before you start buying new things
The battery is good and no it is not getting fire to the plug but it is turning over
Get a new spark plug then try it
Already has a new one
hmmm weird try taking off the spark plug cap and make sure nothing is in it and make sure its getting a good conection and the spark plug is tight
For some reason it is not getting fire to the coil
ok I done some testing the stator has power the cdi has power the orange wire to the coil does not always have fire I used my multimeter and when I touch the wire it goes to -2 or 3 then I push the start button and it goes just about to +20 I stop wait a minute and test it again and it shows 0.00 the whole time even when pushing the start button
