moto 4 axle removal HELP!!!
I've done a Honda 300 once which is probably about the same. Had 2 pipe wrenches, one on each nut. Might have to use a breaker bar on the outer nut, but that one is going to have to come off first. I'd imagine its all seized up. I dont think there is anymore to it other than breaking it over.
I do hundreds of Hondas and the odd Yam, and they almost always need heat, in fact I now Loctite the outer one to ensure they stay tight, (Honda 420 axles come loose with the nuts still firmly locked) and heat breaks the Loctite's seal. If they are rusted fast, the nut needs to be red hot before it will move.
