Where to find the vin number for Yamaha Timberwolf
Old 05-20-2017, 11:06 AM
WB Walker's Avatar
Default Where to find the vin number for Yamaha Timberwolf
I have a used Timberwolf the only numbers found were stamped on the engine were 1500cm3
Is this a 250 or 230?
Where is the serial number located to find the make and model?
Old 05-21-2017, 02:53 AM
150cm3 would make it a 150cc. On most Yams the frame number is on the lower frame tube in front of the LH footrest, but I have never found it there yet. Dealers seem to know all they need for parts, from the code on a white sticker on the frame, under the seat.
Old 05-22-2017, 07:01 PM
Ajax's Avatar
The 1500cm3 is the metric amount of oil that engine uses.
See if this video helps find the vin..
Old 05-24-2017, 03:09 AM
Looks like I was right about the VIN, why can I never find it there? Wrong on the 1500cm3, I think Yamaha do cast the cylinder size on the base of the cylinder though.
Old 05-24-2017, 07:04 AM
greg74's Avatar
Technically it is a 229cc but Yamaha calls it a 250cc. Same displacement as the Honda Recon, which is also called a 250. 1500cm3(1.5L), that doesn't sound like quite enough oil. Generally oil is sold in U.S. quarts, which is slightly less than a liter. I don't think I've seen any full-size quad that required less than 2 quarts. Most take more than that.
Old 05-24-2017, 05:32 PM
Ajax's Avatar
Yea.. engine size is normally on the cylinder somewhere, the oil amount is by the fill/dip stick hole. Atleast thats how my Timberwolf,BearTracker and Wolverine are.
Manual page attached from T-wolfs manual..
Attached Thumbnails Where to find the vin number for Yamaha Timberwolf-yfb250.jpg
mlprus88
Sport Quads
12-05-2017 12:17 AM
MikeyBoyesq
05-03-2017 09:55 AM
jkahall
03-13-2017 12:58 PM
jr102600
10-05-2007 09:11 PM
warrior350megamax
04-27-2002 07:18 PM
Quick Reply: Where to find the vin number for Yamaha Timberwolf
