07 yfz450 back firing.
Try to determine if the backfire is thru exhaust or intake.
If it's the exhaust you may have an exhaust leak. Mine had a leak at the gasket between the pipe and head causing a backfire.
If it's the intake most likely it's lean. Intake leak or carb malfunction.
I would guess intake side as it won't idle.
