07 Wolverine 450 Carb Help - ATVConnection.com ATV Enthusiast Community
Old 05-16-2018, 09:15 AM
Question 07 Wolverine 450 Carb Help
Very amateur mechanic and i'm in need of some help...
I'm replacing the carb on my 07 Wolv 450. The first question of many I'm going to have is - where are all of the adjustment screws located at to make this run right? I've heard tales of one under a brass cap somewhere?
Thanks in advance,
Tim
Old 05-17-2018, 03:39 AM
Anything under a brass cap means set at factory do not fiddle with it. If you have gone for cheapo Chinese, they are not set at the factory and you may have to fiddle with the adjusters.
Old 05-17-2018, 08:14 AM
I think its definitely Chinese, its a cheapo off of Amazon that my kid found. So most likely I need to pop off the brass caps and fiddle with what I find under there?
Old 05-17-2018, 12:19 PM
DirtDevil101's Avatar
Often, they place a brass cap over the A/F mixture screw...on motorcycles they used to do this because they'd run them super lean at idle to pass emissions...you can carefully drill these out to gain access to the adjuster screw (common practice on all Gen1 Yamaha Vmax's)...this mixture screw has the most impact off idle through 1/4 throttle...
Old 05-18-2018, 02:49 AM
If it is Chinese it probably won't have any covers over the mixture screw. Fit the carb and try it. You will have to set the idle throttle stop, but may well get away without adjusting the mixture screw. On some carbs the main jet can be adjusted by altering the height of the needle in the CD piston, by fitting the circlip into different notches on the needle. Again, if it runs right once warm, don't alter it.
MIwolvy
09-12-2007 08:30 PM
07Wolvey450
03-26-2007 05:42 PM
worshipatvs
01-14-2007 05:22 AM
imek
11-08-2006 11:13 PM
24hours
03-26-2006 10:50 PM
Quick Reply: 07 Wolverine 450 Carb Help
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
