1999 yahama wolverine 350 getting hot
Old 06-10-2018, 01:42 PM
Micheal Carver's Avatar
Default 1999 yahama wolverine 350 getting hot
So have about a half hr drive on the trails its starts to spit and spudder then it stalls. It wont even roll over after that. If you let it set for about 10 mins I will start right back up and run great for another half hour or so then the same thing. Its definitely an electrical issue just wondering what it might be. Any help would be appreciated .
Old 06-11-2018, 01:58 AM
"It wont even roll over after that"
Are you saying the starter won't work either? Or the engine is locked up, in which case it is seized, nothing to do with the electrics. If the starter won't work, you have a problem with either the battery leads or the main live from fuse to ignition switch. Whatever, it will be hot, so check when the fault is on for any terminals that are warm. My guess is earth lead to frame.
Old 06-11-2018, 03:39 AM
no it's not locked up I'll check more later and let you know
Old 06-11-2018, 09:47 AM
Jered651's Avatar
Sounds like your stator might be getting weak. Also how long has it been since you adjusted your valves? Or rebuilt your carb
Old 06-11-2018, 10:59 AM
carb was just rebuilt and idk about the valves but they wouldn't make it overheat would they.
Old 06-11-2018, 11:01 AM
how can I check my stator
Old 06-12-2018, 01:16 AM
Jered, he still hasn't told us what he means by "It wont even roll over after that" if the starter won't work when the fault is on, it isn't a stator problem.
Old 06-12-2018, 06:42 AM
Jered651's Avatar
Ive had the stator do that to me before and yes he needs to specify
drhunter1
02-28-2014 11:33 PM
Slicer1989
07-01-2012 06:44 PM
doverust
09-09-2011 09:11 AM
3sds88
03-23-2008 12:56 AM
briski
03-02-2008 11:28 PM
Quick Reply: 1999 yahama wolverine 350 getting hot
