2004 YFZ450 pops and sputters when it gets hot
Old 07-05-2018, 02:02 PM
Bambasher's Avatar
Default 2004 YFZ450 pops and sputters when it gets hot
I have a 2004 YFZ450. It starts, idles and goes great when cold. After some time riding it and it get hot it starts to pop and sputter at high rpms. Also battery dies when it gets hot. Recharge battery and let it cool down and it starts and runs great again until it gets hot.
Old 07-05-2018, 07:03 PM
PolarisXP's Avatar
If the battery is kept charged when hot, does that help?
Old 07-05-2018, 07:19 PM
Bambasher's Avatar
By the time it hets charged the bike cools down.
Old 07-05-2018, 07:28 PM
PolarisXP's Avatar
how about jumping it from another battery temporarily? Electronics hate heat, so anything that might be touching the engine could be cutting out, something like a regulator.
Old 07-05-2018, 07:32 PM
Bambasher's Avatar
Will try that. Thx
Old 07-06-2018, 01:46 AM
If the battery is going flat, sort out the charging circuit. Either there is a very heavy drain on the battery or it isn't charging. Test by starting the bike up and putting a voltmeter across the battery. It should rise with revs and stay there or fall away, but should always be more than when the bike isn't running. The max is 14.5v. To check for a drain, disconnect one terminal and, with ignition OFF, connect an ammeter between battery post and lead, any more than 0.01 amps is too much. This doesn't check for drains in the wiring circuit beyond the ignition switch, but a heavy drain would blow the main fuse.
Old 07-12-2018, 11:53 AM
Jered651's Avatar
Had that same issue on a warrior once and it was the stator.
2001Warrior3fitty
06-14-2018 06:30 AM
Tazzin
05-25-2017 11:56 AM
Ltz399
02-03-2017 08:56 AM
Shreder
07-25-2005 08:05 PM
DuneRider650
07-29-2004 10:27 PM
Quick Reply: 2004 YFZ450 pops and sputters when it gets hot
