2005 Yamaha Bruin starting question
I just picked up an 05 Bruin 350 2x4 ES. I can only start it with the electric start while it is in Neutral. I thought maybe holding in a brake would bypass that? Can anyone confirm? If so, then something is not working as I've tried both handles and the foot brake.
Thanks
Thanks
Only start it in neutral. Starting a bike in gear puts added strain on starter and one way clutch. That is one reason why Yamaha put the "lock-out" on in the first place. Some makers like Suzuki do let you override it with brakes on, not sure about Yams, but don't think so, as the newer models are a pain for faulty gearchange indicator switches, and if you can't get the N or P light you can't start them.
