Neutral switch assembly and neutral pin replacement
Old 11-21-2018, 08:45 PM
Yamahaman68's Avatar
Default Neutral switch assembly and neutral pin replacement
I have a Grizzly 660 that would not display gear indicating lights. I removed the old assembly in crumbly pieces and by epoxying a bolt to the remnants of the unit to get it out of the crankcase. The neutral pin had worn a groove into the old switch. Upon replacement, lights didn’t work. I attached an alligator clip to the neutral pin and was able to make all lights work by touching each switch contact to the clip. This leads me to believe that the neutral pin is worn down enough as to not make contact with the new switch. Can the pin be replaced? Is the procedure as simple as removing the star drive screw holding the plate that holds the pin and spring in place behind the neutral switch assembly?
Old 12-03-2018, 08:15 PM
Default Replying to my own thread
Yes, yamahaman68, all you need to do is back off that star drive screw that holds down the plate that holds the neutral pin and spring in place. Once replaced, the new pin will make contact with the new neutral switch assembly and light up what gear your in on your display. Don’t forget to use blue thread locker on that star screw!
alaskanbowtie
07-12-2020 03:10 PM
blufie
1) Engine problems..
10-24-2019 03:30 AM
Lord Vokk
01-27-2011 12:19 AM
nedflanders
10-12-2010 08:19 AM
fourjs
05-03-2005 07:27 PM
Quick Reply: Neutral switch assembly and neutral pin replacement
