03 kodiak blowing main fuse
I was having problems blowing main fuse.at first I could put new fuse in start it and it would would stay running as soon as I put into gear and try to move the quad the fusr would blow so I started looking for broken or exposed wire found two under the seat in the main wire harness. Thinking I solved the problem. That was not the issue. So I put new fuse in it i move the handle bars and fuse blew again so I removed front rack and plastic removing speedometer and removed the key assembly and found that the wires zeptied to handle bars the kill switch wire hade a brake in it after repairing the exposed wire put everything back together the problem was solved .
