help raptor fan has never worked>>>
since I have had my raptor I have never heard the fan run. Today out of curiosity I got out my yamaha manual and check out how to test it. After hooking + to the blue wire and - to the black the fan ran. So the next step is to check the circuit breaker which is supposed to read 0 ohm. mine reads .5 ohm and when I switch my meter to lo ohm then it reads a flashing .1 and then .0 ohm any thoughts? or just go by regular ohm?
Anyone else have fan problems? ever hear your run?
Mine did the same thing,i let it sit and run in the garage until the warning light came on and the fan never came on, so i did the same test you did and the fan came on so i started chasing wires and under the gas tank there was a wire that was not pluged in it is in a harnass that was on the right side front area under the tank. hope this helps.
I oredered a new circuit breaker and thermoswitch, the circuit breaker was plugged in but is reading over o ohm, and figured I want to know it's all working so just ordered the thermoswitch for the heck of it. I wonder if we can get something different to make the fan come on earlier.
speaking of fans on earlier, I remember good old hypertech! they make some cool stuff. I had a 99 camaro SS LS1, with a 6 speed B&M ripper shifter, skip shift eliminator, 4.10 richmond gears, whisper airbox lid, K&N filter, granatelli air flow sensor, hypertech power programmer, hypertech 160 stat, flowmaster 80 serier muffler, mac off road y pipe (without cats) o2 simms, ya I guess you could say I miss my car!!! by the way it would run hi 12's in the 1/4. (just couldn't afford it with my bike and quad haha)
Alex Rodak
09-13-2015 12:30 AM
Alex Rodak
09-12-2015 09:39 AM
Alex Rodak
09-11-2015 11:42 PM
