ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Yamaha (https://atvconnection.com/forums/yamaha/)
-   -   Warrior Won't Start?>? (https://atvconnection.com/forums/yamaha/43829-warrior-wont-start.html)
WarriorMike Jul 17, 2001 03:36 PM
I went out to ride my 99 Warrior today. I went to start it up and it would hardly turn the starter over. So dad and I hooked up the mini battery charger for a few hours. Went to start it agian and nothening exept for a clicking noise coming from the rear of my 4-wheeler on the left side( its a round electrical thing that I can't spell). What else should I do?? OR what could it be??
PamFalcioni Jul 17, 2001 03:45 PM
Sounds like the starter or the solenoid are toast. Another thing it could be are the starter bearings - check this by putting the bike in neutral and rolling it forward. If it's hard to roll, it's the bearings (the case is weak where they're located, and the shaft can get tweaked in the cases).
If the bike rolls easily, it's probably going to need a starter. Although you might want to check for bad grounds or worn wires before you purchase this $$$ item.
In most cases tho, when the thing makes that click sound, and nothing else happens, it's the starter.
ridnwarrior Jul 17, 2001 04:05 PM
Before spending any money charge the battery again and see how many volts you have in the battery with a voltmeter. A 12 volt battery when fully charged should have almost 14 volts in it. If it doesn't it could be the battery. If a bearing in the starter goes it shouldn't happen from one start to the next. It will be hard starting to the point it won't start, yet a battery can go at any time. If your battery is no good hopefully it's not because the stator isn't charging the battery.
WarriorMike Jul 17, 2001 04:49 PM
ITs still under warrenty so I can get a new starter for free from the dealer. I will check the voltage and all my connections. I might go to the yamaha shop tonight and get a solenoid if that isn't it I'll take it back. I'll post agian if it won't run.
yellowwarrior Jul 18, 2001 01:05 AM
the same thing happened to me with my 99 i thought it was the battery so i got a new one and it was not the battery(wast of money). so i took it to the shop and they send it was not the starter but the thing that make it spin and the starter clutch was bad it was like 350 buck to fix.
NewDSLover Jul 18, 2001 01:35 AM
yellowwarrior~
Just a FYI.
<but the thing that make it spin and the starter clutch>
The starter drive in called the BENDIX.
Blaster96 Jul 18, 2001 12:59 PM
It is posible that the starter siliniod shorted out. the day, or week before, were you riding in any water at all? if so get a new starter siliniod. The starter should be fine becuase my 13 year old starter worked, but not for long. It will not be the starter clutch either. It just dis-engages the starter from the flyweel once the motor starts to spin faster than the starter will.
-this is one reason i like haveing the pull start on my 87 warrior-
WarriorMike Jul 18, 2001 03:44 PM
Went out to the garage and tested the battery its good. We took the starter out and tested it. It barely even spun. So I went out and ordered a new starter today. thanks for all the suggestions
© 2026 MH Sub I, LLC dba Internet Brands
