Does the ProDesign setup use 2 airfilters? If one is it oval like the stock one?
just put one on mine. it is a dual filter setup. according to the instructions it says to run the outer filter in sandy or dusty applications. i run both on mine.
I run both also. When cleaning the inner one is never dirty and I do an aweful lot of sand riding.
Get the pro design kn filter!! it flows alot more than the foam i use the
outerwear and the filter stays clean. it flow so much i had to rejet to 150-155 main jets and 25 pilot jets. 01 BLU 660R GYT-R FRONT BUMPER GYT-R SIDE FRAME COVERS GYT-R SHOCK COVERS GYT-R HOUR/TACH PRM ENGINE SKIDS PRM BAJA GRAB BAR PRO-DESIGN KN 12 TOOTH UNI CRANK FILTER WILDSKINZ HEADLIGHT COVERS DURA BLUE ELMINATOR (MONDAY) |
