Anyone know? Also if you know if there are any A arms or anything else that will fit let me know.
If no one has tried this or isn't sure let me know that too, cause I might try it just to see if it works, I think someone should at lest try because I feel that the blasters suspension is one of it's biggest drawbacks. Thanks, Blaster04 |
no but an lt250 quadracers swing arm will fit with some slight modifications to the shock brackets but the swing arm bolt goes right through it and it works fine the only problem is you have to get a bearing carrier axel sprocket hub and brake disc with it to work but your blaster hubs will bolt tight on
I know for a fact that Banshee front shocks will mount up to a blaster. They give you a whole lot better travel and softer landings, BUT when you turn the front side that you are turning towards will dip down A LOT it feels like you are going to tip over. Hope I could help any.
LT swingarm, which model. 85, 86 , 87 - 90 91- 92
any chance of some digital pictures ?? Thanks Kiwi |
| All times are GMT -5. The time now is 06:26 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
