ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Yamaha (https://atvconnection.com/forums/yamaha/)
-   -   Warrior won't roll (https://atvconnection.com/forums/yamaha/48596-warrior-wont-roll.html)
Spuds Sep 30, 2001 01:20 AM
A friend of mine has a 98 warrior, and in neutral the thing will not roll . You can push it but it is extremely hard to push. We pulled the chain and the axle is free but the front sproket can not be turned by hand. the machine runs fine and will freely shift trough the gears. Some one told us the shift forks needed to be adjusted. Has anyone had this problem? and can it be corrected without complete teardown?
bsr Sep 30, 2001 02:20 AM
Brad if yours dont move with the clutch in that means your clutch is adjusted to tight. Or your clutch might be going bad...
Spuds Oct 1, 2001 12:15 AM
Well we found the problem, after a complete tear down , we found a needle bearing that had work out of the case and was putting the trans. shaft in a bind. the bearing presses in the case half, but it had worked it's way about 1/4 of the way out.
lonestarbanshee Oct 1, 2001 12:44 AM
Where you crash at Spuds?(whats your hometown)
© 2026 MH Sub I, LLC dba Internet Brands
