Is there any difference running 10 inch rear rims? Or is it just for appearance.
Old Oct 17, 2001 | 08:14 PM
alljuice's Avatar
I was thinking about buying some new tires and rims and I havent seen anybody buy 10 inch rims on the rear except for the dunes. What are the pros and cons if any. Thanks
Old Oct 17, 2001 | 08:51 PM
TitanRacing25's Avatar
I've heard this and it really makes sence to me, you get less bite with 10 inch rims due to less sidewalla flex, just what i was told!
Old Oct 17, 2001 | 09:06 PM
trx250Rob's Avatar
Sidewall flex give you less traction since the side of the tire has little if any tread, the reason you don't see it too much is that there is less tire and more rim, so you are more likely to bend your rim on a rock especially if you lower the pressure to get more tracion. Personally I don't care, they look good.
Old Oct 18, 2001 | 04:58 PM
garyc660R's Avatar
Yep, Rob is right....the wider rim is more likely to snag on rocks, etc. The dune guys don't have to worry about that.
Old Oct 18, 2001 | 06:24 PM
01TRX300EX's Avatar
I would actually make the quad a little lighter since rubber weighs more than aluminum. Therefore more aluminum and less tire means lighter weight.
Old Oct 19, 2001 | 09:55 AM
sAyIt_fmf's Avatar
along with the weight difference......Anyone who has ever rode behind someone in the sand knows how much a paddle tire can expand under power. Like a dragster on the strip. The tires would balloon right up with a smaller rim.
Old Oct 19, 2001 | 10:25 AM
TitanRacing2's Avatar
i've got ten inch rear rims on my tecate (douglas red label). true, they will bend much easier after a large jump because there is less rubber to absorb the jump, which is why you see tiny 8 inch rims in MX, but i think that the ten inch rim looks awesome. i'll stick with the tens, it just depeds on what you like.
SOLOLUCKY
Oct 4, 2024 09:09 PM
txkevin
Sep 21, 2015 02:02 PM
AK47KID
Jul 23, 2015 09:21 PM
scaldwellk
Jun 19, 2015 05:08 PM
CountryMiles
Oct 25, 2000 01:03 AM
