Hi, I have a 99' Yamaha Timberwolf. Does anyone know of any other tire that will fit on my stock rims. I like the stock tires for what I ride in (mostly shale, dirt, some mud, snow & water) but would like to try something else when I buy new tires. Thanks for everyone's help.
Sean Sicher |
I have a 99 BearTracker and I put some Titan 489s on it, the tire is a lot better in the traction department and is lightweight too. The size on them is the same as a stock t-wolf or b-tracker except for the height the sizes are 23x10x10 in back and 23x7x10 in the front while that did add an extra inch of ground clearance, there is not a hint of any performance loss but that may be different because if i'm right a timberwolf has a 24mm carb while a beartracker has a 34mm, but I could be wrong about the t-wolf and the loss due to a smaller carb.
Im running Carlisle Tire Co.'s 22-11-10 Stryker. i think they are a pretty good tire, and they fit my rims and only hang out an extra inch.
