Ok I have had enough of that stupid rev limiter for reverse. I need to know how to by pass it. Also can anyone tell me what oil to use in the Raptor, I am at work and did ot bring my manual. thanks again.
Any help would be greatly appreciated. |
What you need to do if find 2 wires under the front sprocket. One wire is held in with a screw, and the other wire is a push on type connection. Find the one with the push type connect. You will need to find some type of switch, preferrably a momentary switch, and splice (do not cut) one end of the switch into the wire that is the push in type, and attach the other wire from the switch to a ground on the motor. Mount the switch where it is comfortable for you to use, and when you need the power in reverse, just hold down the switch while in reverse, and you should have full throttle in reverse. Let me know if you need anymore info.
Reverse limiter
FYI: REVERSE LIMITER
Warning: Dangerous Modification To bypass the reverse limiter on ALL model year Raptors is to cut the GREEN/WHITE wire near the CDI box and ground this wire that goes into the ignition. This tells the CDI that you are in a forward gear, however the ignition will not be able to turn on the reverse indicator light. -Joe (not from the TV show) |
Reverse limiter
Has anyone tried a REVERSE drag race yet??? Maybe there could be something too this.
