Trailtech light install question on a Raptor
Old Jun 14, 2002 | 01:50 PM
RaptorLou's Avatar
I just installed my new Trailtech lights on my Raptor but did not hook up the wires yet. They are mounted on the dashboard by the computer. My question is where is the best place to tap in for power? I want to hook the light's up to my highbeam switch so when I hit the high beams the stock lights will be off and the Trailtech's will be on. I know what the color code of the wire is for the highbeams, I just am not sure where I can tap into at. I can run a wire from each light and go up to the Trailtechs, but I would like to tap in closer to the handlebars. It is hard to see the wires come up because the radiator gets in the way. Where did everyone else tap into?
Old Jun 15, 2002 | 10:45 AM
THEMOOSE's Avatar
I just tied in to the batt for my power & used a seperate switch.
Let me know what you find because I'm going to get the Trail Tech Lights that replace the stock lights & will hook the handle bar lights to the hi beams when I do.
Old Jun 15, 2002 | 11:08 AM
RaptorLou's Avatar
Here is what I ended up doing. I pull the front fenders off and disconnected the stock headlight wires. I was able to pull the yellow wire out of the connector out of each headlight, and wired it to the Trail techs. The 2nd wire on the Trailtechs I grounded to the frame. Now when I turn the highbeams on the stockers go off and the Trailtechs go on. When I switch to the low beam, the stockers go on and the Trailtechs go off. I'll tell you what, those Trailtech lights are BRIGHT!! I really like them.
Old Jun 15, 2002 | 01:56 PM
Laeger's Avatar
Thats a good Idea I like the setup, I'm going to get some TT light for my shee that mount in the stock location.
-Steve
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
yambam13
Jul 4, 2015 01:49 PM
