weird noices on kodiak when first started
Old Mar 12, 2000 | 09:41 PM
justhonda's Avatar
it was pretty cold this mourning (37) when i went to start the quad it started , then it was making a weird noice on just a little throttle, anyone have any ideas, or is it normal
Old Mar 12, 2000 | 11:28 PM
Yammer_Hummer's Avatar
Justhonda,
What are you doing with a Yamaha? Are you going to change your Forum UserName?
Seriously though, one thing that may help diagnose this problem is whether the noise goes away once the Kodiak is warm,does it stop at higher RPM levels, get louder, change frequency?
Yammer_Hummer.
Old Mar 13, 2000 | 12:59 AM
ryant's Avatar
My dealers mechanic (who took almost an hour of his time to go over every little detail of my machine!) told me it is normal when first started in cold weather. I would guess it has some thing to do with the oil system.
Old Mar 13, 2000 | 02:17 PM
ahamay's Avatar
I think the noise you are hearing is the primary clutch spinning. Mine makes a strange whirring sound at startup when it is cold, and it seems to be comming from the clutch area.
Old Mar 14, 2000 | 11:21 PM
justhonda's Avatar
well today i finally found the noice, I was getting so frustrated with the noice i took the cover off and found that on the main clutch there is 4 little screw, and one was half way out, so i took them out and put a dab of loctite on the threads. thanks anyway.
MikeyBoyesq
Nov 27, 2020 02:44 PM
sae156
1) Engine problems..
Jun 3, 2015 01:45 PM
1000gade
May 27, 2015 12:37 PM
elmer119
May 24, 2015 10:51 AM
