Help with blaster cluth
hey i had to replace a piston in my engine so me and my buds took out the whole engine replaced the piston and rings and then put it back in there.. started it up no problem. then i noticed that we couldnt shift gears my cluth wasnt working. when you pull the clutch lever it movies the cables and moves the thingy its supposed to move... what went wrong?? why doesnt it work now? it worked b4 we took it out any help would be gr8 the blaster engine is now once again sitting on my desk
Did you have the clutch cover off?
try adjusting the plucth push rod adjustment and the clutch cable fre play |
