my mechanical disc brakes............
ok here it what u need to do take the 3 allen bolts out of the side of the caliper pull the caliper apart the side half then take the white gear lookin thing and pull it out a little to unseat the teeth on it (this is the adjuster) turn it whichever way it will turn it shouldn't click or you turnin it the wrong way when u get them to seperate alittle put a screwdriver in between and pry them apart
ok now put the brake aliper bake to gether make sure you line the little pin up in there you will see it
when your caliper is back on pump your brake a bunch to get the adjuster to adjust them
Customer Service #1
05-15-2020 08:46 AM
