ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Yamaha (https://atvconnection.com/forums/yamaha/)
-   -   I need roostking's and other banshee feinds advice.. (https://atvconnection.com/forums/yamaha/83829-i-need-roostkings-other-banshee-feinds-advice.html)
800 Dec 29, 2002 05:44 PM
I just sold my banshee because I was having too many problems with it. I am looking for a "new" used banshee right now. I am having withdrawls! I am looking for one that is in the 1995-1999 year range. When I go out to look at used banshees what should I look for to tell if it's in good shape?
Can you give me some pointers and trouble spots to look out for.
thanks
800
Ernie660R Dec 29, 2002 10:14 PM
I own a 89 Shee, I love it. OK to answer your question, it should start within the first two kicks. If you have access to a compression gauge check the bike you are looking at 150psi or higher is good, and there should be no more than 5psi difference between cylinders, thats my opinion. Must important ride it to check for any shakes, rattles, or trany problems. LOL[img]i/expressions/face-icon-small-smile.gif[/img]
RoostKing Dec 30, 2002 03:48 AM
If you have the time, check for any play in the swingarms bearing or the axle bearings. When you test ride it, run it through all the gears, (dont have to be hauling butt to do it, just shift through to make sure they are there). Cant quite think of much more right now... Let me get a cup of coffee down and i might be of more help. LOL
RoostKing...
800 Dec 30, 2002 01:34 PM
Thanks, so basically wiggle the axle back and forth to see if it slips in the carrier...ect
800
© 2026 MH Sub I, LLC dba Internet Brands
