warrior sprocket
i want more top speed put of my warrior and i want longer gears. They seem too close for the riding i do. first gear is pretty much useless and sixth seems way too short for me.what size sprocket do i need and will i be able to use the stock chain? how much will it cost?
warrior sprocket
YO did you figure out what is a good size to go to?
warrior sprocket
i have 14 tooth sprocket on mine and seems to go faster and the gears are further apart
warrior sprocket
Originally posted by: bvwarrior i have 14 tooth sprocket on mine and seems to go faster and the gears are further apart |
warrior sprocket
how much bottom end did yall lose putting a 14 tooth sproket on just guessing
warrior sprocket
Originally posted by: FoxSpirits Originally posted by: bvwarrior i have 14 tooth sprocket on mine and seems to go faster and the gears are further apart |
warrior sprocket
WELL POINT BEING IS IF YOU GO UP A TOOTH ON THE FRONT SPROKET YOU WILL GAIN TOP END AND LOOSE BOTTOM END THAT WAS MY FUC!ING QUESTION
warrior sprocket
Originally posted by: 2FAST4URASS how much bottom end did yall lose putting a 14 tooth sproket on just guessing |
warrior sprocket
thanks for the reply foxspirits
warrior sprocket
Yo where did u order your air scoops>?
