Weekly Used ATV Deal: Polaris Sportsman 400
Main
The cold of winter has us out in the workshop but spring is on the horizon. Getting out and shredding as the leaves are budding and the creeks are rolling makes the off-season worth enduring. Your ATV Connection editors are still monitoring SprocketList for good deals on previously loved equipment to make those rides a reality.
That said, this week’s ad takes us to a place called Los Angeles, CA.
According to the listing this is a Polaris Sportsman 400 with Warn 55″ plow. Said to be a good running machine, it has selectable 2/4WD, Hi-Low range/park, and front brush guard.
“Everything works fine, brakes, lights, battery, 4wd, etc. except the speedometer unit…I do have a used one available that will go with though, just not from this machine, so I cannot tell you the miles or hrs, nothing shows up on the display”.
The seller goes on to say it does have a few battle scars: rear rack is cracked/broke, just cosmetic, and the seat has a small taped up spot right on the front edge, and the right floorboard edge has some damage. He also says “Ok tires, although they are worn down. Starts up, idles right, and runs out strong, needs nothing, ready to ride”.
He’s looking for $2,100 and is not currently considering trades.
