06 400 wont start HELP
Old 05-22-2009, 12:17 AM
klerpo's Avatar
Default 06 400 wont start HELP
My 2006 400 4x4 auto just wont start, i put in a brand new battery and it still didnt start, so i jump started it and while it was hooked up it had lights and the display worked, after unhooking it, it will run fine but no electronics work. what the hell is wrong with it?
thanks
Old 05-22-2009, 11:06 AM
mudslinginfool's Avatar
Does it in the Mud!
a friend had the same issue. It was a defective battery. He had nothing on the display either. his would actually start though. Make sure you charge the battery before you put it in. I would test the battery.
Old 05-22-2009, 11:28 PM
swampyjunior's Avatar
To test your battery remove it from the machine and put it on a trickle charge of 2 amp for about 12hrs. Then, using a volt meter check the voltage across the terminals. IT should read something just over 12volts. Wait about 8hrs and put the volt meter back on it again. Your readings should be very close to each other.
Last time I had a battery issue I had 12.8volts after a 12hour charge and about 6 hours later had about 10volts. Unless you use a battery maintainer that keeps a .2 amp charge going to the battery or something in the 1-2 amp range with a float or full charge sensor you will be lucky to get 2 years of use out of those little batteries. Especially if you have a winch and use it a bunch.
SJ
Old 05-23-2009, 11:53 AM
klerpo's Avatar
thanks ill give it a try if it doesnt work il try checking the stator hopefully it works
MikeyBoyesq
11-27-2020 02:44 PM
Mkp
03-28-2020 03:50 AM
tiresharkdbb
09-03-2017 02:06 AM
garyt1975
06-05-2015 08:53 AM
1000gade
05-27-2015 12:37 PM
Quick Reply: 06 400 wont start HELP
