atv leans
Old 11-23-2009, 04:56 AM
arctickatman's Avatar
Default atv leans
i bought this bike new but ive noticed lately if you look at it head*on the left side is dropped about 2 inches.anyone know what causes this or has had this problem?dosent seem to affect the ride or drive just looks strange.any help is appreciated.thanks.
Old 11-23-2009, 01:21 PM
mudslinginfool's Avatar
Does it in the Mud!
same amount of air in the tires? could the plastic possibly be out of wack? ever roll it or flip it? On level ground measure from the ground to the floor boards on each side and this will tell you if its your frame out of wack, or just the plastics.
Old 11-23-2009, 05:08 PM
its never been flipped or rolled, thanks i will measure floorboard height and see.thanks
Old 11-23-2009, 05:57 PM
swampyjunior's Avatar
Measure your shocks and springs on each side to make sure they are the same. The large ATV's have a tendancy to have spring sag from the dry weight of the machine over a period of time. You may need to replace sprins and or shocks or both.
It may also be that the shock settings are lower on one side allowing the sag. But ineither case measure the length of your shock center of bolt to center of bolt sitting on level ground. Compare your measurements. If they are the same I would look at plastic and or Frame.
SJ
Dammar
04-20-2016 06:03 AM
cswiger
Polaris Side by Sides
12
10-05-2015 03:34 PM
Bonzhonda300ex
TheATVSuperStore
09-17-2015 01:21 PM
bvolks
09-13-2015 12:57 PM
Minimod
09-10-2015 09:20 PM
Quick Reply: atv leans
