triz oil change ? asap
Old 01-14-2007, 11:48 AM
lost1wheel's Avatar
Default triz oil change ? asap
1985 tri z 250 i need to do oil change waht kind of oil, how much oil? is their a filter?
Old 01-16-2007, 05:29 PM
3Wheels4Life's Avatar
I use 10 30 oil no filter take the oil cap off and the oil check screw (below the cap on the side of the case) and fill it until it starts to come out and then put the screw back in and cap on and your good to go
Old 01-17-2007, 01:01 AM
lost1wheel's Avatar
thanks
Old 01-18-2007, 01:38 PM
daron's Avatar
you are talking about the gear oil right. because on a tri z the engine lube oil is mixed in with the gasoline. U need to use gear oil too. not 10 W 30
ReconBayou
10-31-2022 05:37 PM
ultangler
09-05-2021 08:06 PM
Jackg17
Ask the Editor
07-16-2018 04:01 AM
Sw00p
09-24-2015 02:50 PM
XxS0ccerstarxX
09-22-2015 02:40 PM
Quick Reply: triz oil change ? asap
