Stock Carb Mods - Summary
Old 02-28-2008, 10:17 AM
boomer8201's Avatar
Default Stock Carb Mods - Summary
Thanks OMR!! I'll start at 3 and see how that goes
  #102
Old 03-01-2008, 11:42 AM
boomer8201's Avatar
I got the carb back on and started her up and she runs great! I couldn't take it for a test ride but I let it warm up, adjusted idle to 1450rpm and reved on it a few times. throttle response is awesome! she was boggin down low probably because of the cold but now it's crisp! I rode it from my garage to the fence and now I really can't wait to take it for a spin! I left the pilot screw at 2 turns right now until I get my cdi and endcap. Need to change oil and plugs so I can really see how rich/lean she's runnin. I'll probably step down to 89 octane instead of 93. I feel like I'm a kid again! lol
  #103
Old 03-08-2008, 10:31 PM
Sport400inOH's Avatar
In the summary, there was a 47.5 pilot mentioned. My 2003 DS has a 40, and my dealer can only get 45 and 50. I opted to order the 45. I've also got the DJ kit & K&N w/outerwear on order. Now that I've read all 6 pages of this thread, I'm wondering with the DJ kit being more rich at idle, do I need the larger Pilot? Also where should I start for the Pilot screw setting with the 45 Pilot (K&N will arrive with the DJ kit, closed airbox, stock CDI and stock exhaust)?
I'll make the other mods after I get through my first round of bolt ons.
  #104
Old 03-09-2008, 01:46 AM
OMR's Avatar
OMR
OMR is offline
Is Oldmanracing! Also the inventor on the DS650 carb Mod!
2 turns out if 60 degree's or warmer
2 1/2 turns out if below 60
The factory sometimes used a 40 and sometimes a 45.
With DJ kit 45 works great.
  #105
Old 03-13-2008, 03:58 PM
dozer103's Avatar
i have a ? about the bleed off screw on the right side of carb. do you only put in a 40 if you plan on running with out a lid. and also what tool do you use to measure float level. thanks for the help.
  #106
Old 03-21-2008, 08:42 PM
SilverBomb's Avatar
SilverBomb has got an Addiction!
TTT
  #107
Old 03-24-2008, 04:09 PM
Lhduce's Avatar
OMR i need you in my other post so i had quick question on what target AR for the ds650. Also do you know what the factory AR was stock at idle and wot. Thanks.
  #108
Old 03-25-2008, 12:27 AM
OMR's Avatar
OMR
OMR is offline
Step 10 and 11 added to Stock Carb Mods - Summary
OMR
  #109
Old 04-28-2008, 01:51 AM
NDoggDS650's Avatar
Ok question is this: New to the world of DS650's I bought a 2000 DS650 from a guy that bought it directly from ALBA Motorsports new, has Ron Woods exhaust, K&n fiter and air intake scoop things. So heres the problem. It hauls *** off the the line, but falls flat on it's face in 3rd gear. It's got nothin'!!!! So I had the carb cleaned and rejetted, but it seems to be worse. I also have a 15 tooth sprocket on the front instead of the stock 16 tooth, and smaller tires on the back. Does this sound like a "fuel/air" issue that just needs to be dialed in?? Or maybe something else??
  #110
Old 05-09-2008, 01:07 AM
bigmo4126's Avatar
im interested in the comlete kit, once this is done will i need to do anything else, like change the main jets. send me the price my email address is cmosleytwo@msn.com
Quick Reply: Stock Carb Mods - Summary
