110cc go Kart motor Bending Valves???
Old 01-25-2014, 08:39 PM
Littlep2468's Avatar
Default 110cc go Kart motor Bending Valves???
Ok, here is the deal. Motor had no compression. Pulled it apart and found a bent Ex valve. Replaced both valves and valve springs, piston, piston rings and all gaskets. Motor ran for about 5 mins and stopped. Tore it down and ex valve bent again and i noticed the timing was off 180 degrees. Replaced valve and again same thing. Ex valve bend and timing off 180 degrees. Anyone out there have a clue as to what is going on?????
Old 01-26-2014, 10:10 AM
Zrock's Avatar
Super Quad Patrol
Did you fix the timing? If you fixed the timing and it did it again your chain and tension is probably bad or timing gears.
Old 01-26-2014, 02:30 PM
brumbear's Avatar
just get a harbor frieght 212 motor for 99$ and no worries
Old 01-27-2014, 07:47 AM
Thanks for the replys. I found that the timing is fine. on 4-strokes every other TDC it will back like it should. The timing chain is tight, I do know that. I have just order a manual so that i can tear into the bottom end. Off hand do you know how to lossen the timing chain?
ronnierhino06
11-09-2015 12:56 PM
randycraft24c
08-05-2015 02:50 PM
Hankey Pankey
07-31-2015 05:50 PM
Waddell4436
1) Engine problems..
07-20-2015 09:46 AM
Waddell4436
Technical and How-To Articles
07-19-2015 04:22 PM
Quick Reply: 110cc go Kart motor Bending Valves???
