STUCK IN GEAR (((PLZ HELP)))
Old 04-26-2008, 04:32 PM
jezebel's Avatar
Default STUCK IN GEAR (((PLZ HELP)))
2005 hammerhead twister, clutch is engaged when trying to start...goes into either gear easily...but clutch does not disengage , and it will not freewheel when it is off or stopped. Any ideas? Anything I can run with...I will try anything, Is there a tranny cable adjustment on a hammerhead? Any1? Thx for any help in advance....
Old 06-03-2008, 12:54 PM
RonV's Avatar
Can you expand on your problem? The hammerheads have a CVT (continuously variable transmission). It's belt driven. Are you saying that it will move forward without applying throttle? It should run and then when you give it gas, the clutch will engage and then you move forward.
Old 06-27-2017, 04:44 PM
Viking1976's Avatar
I have the same issue...tries to move when starting like it's stuck in gear. Switched to reverse and the same issue. When it's running, it will stall when I come to a stop from being "in gear". Is there a clutch adjustment or even a cable adjustment that could fix this? It's a 2005 Twister Hammerhead 150...
Njrider1230
07-29-2023 05:16 AM
Polaris5
08-29-2015 09:11 PM
heath legg
07-24-2015 01:01 PM
micheleLeigh
Technical and How-To Articles
07-19-2015 07:32 AM
ghost civic
07-15-2015 10:48 PM
Quick Reply: STUCK IN GEAR (((PLZ HELP)))
