keihin 34mm carb on 250r
I just picked up an 86 trx250r from a guy in pennsylvania . the bike ran strong there but after getting the bike home (on the gulf coast) not running as strong and will not idle . try to adjust air flow on carb (keihin 34mm pj) but no difference.
also how often do I need to replace rings ? and where can I get factory plastic and a good selection of replacement parts?
Do to the elevation change, it's a good chance that you will have to rejet the carb. If the bike has a stock motor then don't replace the rings until it blows up or starts smoking alot. That way you can upgrade to a 330kit;^) For those of you reading I was just kidding. The rings really depend on the riding you do. Some shops recommend doing a top end every other year based on hours of riding. I've gone 8yrs before I blew up my stock motor without changing rings. My piston blew up due to to hot a plug and not enough premix. My fault though I was out of gas and fouled my plug but wanted to ride longer so I borrowed my buddies parts and fuel. As far as factory plastics, you may want to price them out before buying. They are much more expensive than that of say Fullbore.
CRamshaw777
07-18-2015 05:46 PM
