wheels size 400
wheels size 400
Got an owner's manual??? It will tell you what the "stock" suspension settings are. I would reset it to stock, then ride it and adjust it to your personal taste after that:
http://atv.off-road.com/atv/ar...eDetail.jsp?id=192286
The shake could be tires or even a bent rim.
Not sure what you mean by "smaller" tires. In any case, I would ditch whatever it has on it, and get some aftermarket tires. I run ITP Holeshot XC's, but I ride desert. I also like to run ITP rims, because they are wider than stock and have a greater offset. This makes the quad several inches wider...for a real nice increase in stability.
Hankey Pankey
05-01-2018 01:33 PM
Hankey Pankey
08-17-2015 05:01 PM
