400ex a-arm modification
Old 07-27-2015, 10:13 AM
metal249's Avatar
Default 400ex a-arm modification
My 400ex has either a bent frame or a bent a-arm, which is causing a different camber on each front wheel. This could be easily resolved with adjustable upper a-arms. The front hiem joints are tapered where they connect to the spindle, if i could locate some hiems that match this taper, i could just modify the stock arms to be adjustable. Anyone have a source for these joints?
Old 07-28-2015, 09:35 AM
Scooter86's Avatar
Knows Old ATV Questions!
If it is a stock arm that is bent, good time to upgrade to aftermarket. Word case, you can get a used set of stock arms cheap and have some spares. If it is the frame, well I would look to fix that if possible.
XxS0ccerstarxX
09-24-2015 11:53 PM
XxS0ccerstarxX
09-24-2015 05:38 PM
XxS0ccerstarxX
09-24-2015 02:02 PM
XxS0ccerstarxX
09-22-2015 02:40 PM
Ridgerunner665
09-15-2015 01:20 AM
Quick Reply: 400ex a-arm modification
