LT80 Secondary clutch rebuild
Before I put the clutches on this past weekend I started to clean out some of the corrosion. After a few brushes with a wire brush. I see oil weeping out of the transmission cover. Took me about an hour to get it off. The steel pin it anchors on was corroded to the cover. I had to take the chain of to tap on the output shaft so i could tap the cover off. Think this chain and sprokets are worn out? ;-)
Not bad for 29 years old
04-13-2016 06:57 AM
