Is this a normal noise?
Old 07-06-2016, 07:05 PM
Boxertim's Avatar
Default Is this a normal noise?
I have a 2011 polaris sportsman 550 touring eps.
Purrs like a kitten when it starts. It also sounds normal when it is accelerating. When I take my thumb off the throttle after it has been accelerating or going at a constant speed, it sounds like there is rattling from the middle centre (though it could be from anywhere I guess) for a short time.
Is that a normal sound?
Edit....It is definitely not a grinding sound.
Old 07-07-2016, 08:06 AM
Sounds like normal drive line lash or ****** as some call it. You have to consider that power from the engine goes to the drive clutch then to the rear clutch,then to the gear case shaft and then to the driveshafts. There's a little slack between each point of power transfer that causes the noise.
GoinCrzyWanaCom
04-13-2016 10:16 AM
thl1222
02-29-2016 08:09 PM
TraxxasBeamer
02-27-2016 08:47 PM
PolarisPower500
05-17-2015 02:28 PM
patriot96
10-08-2002 01:22 PM
Quick Reply: Is this a normal noise?
