2001 Polaris Xplorer 250
Old 04-11-2008, 12:03 PM
snowolson's Avatar
Default 2001 Polaris Xplorer 250
I just picked up a 2001 Xplorer with about 500 miles on it. The previous owner wasn't exactly sure on the mileage, but said he thought they had gone through about 4-5 tanks of gas.
Concern:
At low RPMS, the engine makes a consistent noise. Not sure if I would describe it as a ping or a knock. Don't think it is piston slap, but not sure. It sounds like it is coming from the cylinder area. When you are riding at slow speeds, the noise persists. When you get the RPM's up, the noise disappears. Does anyone have any idea as to what I should look at to solve this problem or is this normal? Looking for some direction.
Thanks
EBYE@JUNO.COM
Old 04-11-2008, 04:54 PM
drlang's Avatar
Look at the primary clutch buttons.
Old 04-11-2008, 04:59 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
not sure about anyone else 250 but our trailblazer was fairly noiset at low rpms yes it sounds something like pinging. if it truely has only had that much gas ran thru it then i wouldnt think it would be too worn out. imo.
Old 04-11-2008, 05:38 PM
snowolson's Avatar
drlang-
I pulled off the clutch cover and cleaned everything up. Nothing was loose or worn. I am wondering if the rings aren't bad and creating piston slop? Thanks for the advice.
Old 04-11-2008, 05:42 PM
snowolson's Avatar
stendori-
I agree, nothing should be worn that could cause mechanical failure with this low of miles. We bought it from a family that had it for their kids. Shouldn't have had a lot of abuse either. Any suggestions on what I might try for gas to see if that helps the problem? Any other suggestions?, or just forget about it and get riden!
Old 04-11-2008, 05:53 PM
drlang's Avatar
Cool, good point on the useage-hours. Now slip in a Polaris green spring and away you go.
Cole Hadden
08-24-2020 11:11 PM
maxjung
07-14-2015 12:29 PM
maxjung
07-14-2015 12:11 PM
maxjung
07-14-2015 03:10 AM
maxjung
07-14-2015 02:22 AM
Quick Reply: 2001 Polaris Xplorer 250
