no spark to plug when using electric starter
Nope! My manual shows the same. The main thing is to check fire with the plug grounded to the cylinder and see if it has spark while cranking with the starter.If it does have spark it isn't the switch! If it only has spark in the on position and with the recoil starter only,you can pretty well say the switch is the problem. I treated switches the same as testing a cdi as the manuals recommend. "Replace with a known good one" Good thing I had the shop and usually enough parts in the parts room to swap out switches,cdis,speedo's,etc. Tough on the owner to guess on what's bad at times and have to throw parts at it when the manuals don't show enough tests. OPT
Now what I did today, was fully charge the battery, tested volts with digital meter got 12.9V .
I then used my Dmm to test the battery volts draw when cranking, and I got reading of 11.55V for 10 sec or so, nothing lower
I tried to start the engine with electric starter but no spark. I pulled the plug and grounded it to frame, still get no spark, I reinstalled the spark plug. I had to pull start it and fired right up on second pull. I then checked battery voltage at idle, got reading of 14.50-53 V (jumping back and forth) and about the same with engine idle up.
The next test I ran was, with engine at idle and battery voltage at 14.50-53 V (jumping back and forth) I flipped the headlight switch on low for a while to observe the battery voltage drop. I got all the way down to 12.48-54 (jumping back and forth)
I then moved the switch up to high beams for a while, and the battery voltage went down to 12.22 V I went to hit the throttle to idle up and it instantly quit running. I then put the key switch in the off position and read my DMM and got 12.45 V at battery so I lost some volts
from my experience, I should be able to let this engine idle for a while and still have a fully charger battery when I shut it down, and the charging system should overcome the use of all accessories when in use?
maybe a charging issue?? and a ignition switch problem
I think maybe I'm in the right area of searching for this issue, but not confident yet that I'm in the right area, maybe I'm missing something
Last edited by lovetowrenchit; 12-09-2012 at 01:51 PM. Reason: added :and ignition switch issue
Sure sounds like a faulty switch. Check this place out. Item #17 (switch) has been superceded with a new part # which usually means problems with the old one.http://www.cyclepartswarehouse.com/f...007&fveh=11299
OPT
OPT
Sure sounds like a faulty switch. Check this place out. Item #17 (switch) has been superceded with a new part # which usually means problems with the old one.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
OPT
OPT
At idle voltage is at 14.5 volts which is perfect! Even though the battery voltage may drop a little with all the lights on,etc, if the battery (while sitting) builds back up to 12.5 to 12.8 volts,then I would just replace the ignition switch. Especially since you said you have no spark at the plug while using the electric start and do have spark and will crank up with the switch in the on position and recoil starting. This just shows that the switch is shorting out and this is what I'd replace. The ONLY other thing I can think of to check is if the cdi does have a black kill wire leading from it,pull this wire and see if you have spark then while using the electric start. Just trying to eliminate any internal cdi kill circuit problem or left control switch which the black wire ties into. OPT
#15
so I think I'll purchase that ignition switch, and go from that point
#18
#19
I must ask, is the rev limiter wired into the cdi? I'm looking at the 2009 manual it shows a separate block for the rev limiter. This is an 2007 so thinking not much difference in the wiring between the 2 years, is this correct
