Trailblazer 250
#31
Thanks for the reply. I found the main issue to be the chain. Must have been a mixture of riding through mud and water. A good cleaning and lube seems to have stopped the grinding for now but the chain has side to side play in the links. I already replaced the silent chain from the advice you gave me a awhile back. I'm saving up to go through the whole machine. My wife really likes the wheeler so I decided to restore it and not sell. It's a fun little machine. I think my next major step is a leak down test, I'm getting idle drop randomly, bogging and last winter it didn't want to start very easy. Thanks for all your help, I appreciate it.
#32
#33
If you plan on leaving the spark plug in going through the intake manifold as the test area,just pull the timing plug on the recoil cover,slowly pull the recoil and watch as the 3 timing advance marks pass,then the "F" for for ignition,right after it is the "T" for tdc. It may be inverted. Stop there and be sure to have no more than 7 psi or you will have to replace the crank seals for sure as too much air will pop the seals. On home made testers,most people use bicycle pumps or low pressure pumps of that nature. Use soapy water around the head gasket,base gasket,engine case,etc. If it's leaking anywhere in those areas you should see bubbles. If the pressure drops but you can't visually see leaking,then most of the time it's crank seals especially the one behind the drive clutch.
#34
#35
#36
#37
#40
