Polaris trailblazer 250 interment spark when revved
Idles fine but when the quad is revved it sputters and shoots has back out the car but won't die. I checked the spark and it is fine at idle but at the top end it is very interment. Bad coil? Bad Cdi? I really don't know. This quad had been completely rebuild except for the electrical stuff. I had it running fine and then my friend flipped it and it hasn't ever been the same since.
It's not a problem that reverse was limited as that's what the module was designed to do unless you pushed the reverse over ride button. It's when it fails(all of them do) that it can limit in forward range also. Just a useless safety device that constantly fails and really wasn't needed as many brands don't even have one.Glad it was a simple fix for you.
