2015 Polaris Sportsman ETX EFI Ignition?
Old 02-23-2017, 04:58 AM
buckeyparker's Avatar
Default 2015 Polaris Sportsman ETX EFI Ignition?
2015 Polaris Sportsman ETX EFI A15SEA32AH
Can't figure out what is wrong with my ATV. It was working just fine the other day and then all of a sudden when you turn the key, it WILL struggle to turn over. If you can get it to start, you thenhave to HOLD the key in the start position for it to stay on. Let go of the key and it shuts off. You also have to turn the key repeatedly to CRANK in order for it to crank up. I figure this is an ignition issue but I didn't want to take it in to a shop and have to eat all those fees if someone can help me out in identifying the exact part I need to replace I would be eternally grateful. Please help. I have literally pulled my hair out trying to figure this out.
Old 02-23-2017, 06:16 AM
Check the battery connections first and have the battery load tested.May be as simple as that.It may show 12 volts or more but under a load battery voltage can drop if you have a weak cell.
