Taotao 250d help
Old 01-21-2017, 06:42 PM
Coyotedogg's Avatar
Default Taotao 250d help
So i got this thing ran ok saw the front sprocket was toast put a new one on and a new chain which i had to cut to size and moved my axel back looked good.(waiting for a rear sprocket)Now it just skips and jumps in forward and simply grinds and barely moves in reverse. Where did i go wrong? Im hopeing i didnt bend a link in breaking the chain i did buy the tool for it. (new to mechanics in general)but would that cause this?
Old 01-22-2017, 10:36 AM
Zrock's Avatar
Are you sure you have the right pitch. Front sprocket and chain are the same as the rear. Is it jumping on rear sprocket? Rear could be warn enough that its jumping with the new chain
Old 01-22-2017, 08:27 PM
Coyotedogg's Avatar
Whats a pitch and i got them from whygostock rhe rear is in good condition the front had no teeth at all so im perplexed its running worse. Even does this with the old chain just in reverse...
Old 01-22-2017, 08:35 PM
Zrock's Avatar
Their are several different pitch of sprocket/chain. some may fit on others but will jump.... if you look at the old chain or sprocket it will have a 3 digit number stamped on it...
I made this mistake when I changed chains
