Water getting in gas
Old 02-28-2017, 12:36 AM
Xdzombiezz's Avatar
Default Water getting in gas
when I go through water I keep getting water in my gas I don't go crazy deep wasn't past the tire and I'm not sure where to start looking
Old 02-28-2017, 07:08 AM
Tank vent,gas cap not sealing properly,through the air box,etc. Several places water can get in.
Old 02-28-2017, 08:07 AM
hydrex's Avatar
1 thing that I've seen in older Arctic Cats= Crack in the bellows between the carb and the motor. While it's probably not your problem, just a heads up for AC guys. I always put Phaze Out in my gas, fingers crossed no water yet. Check the routing of your gas tank vent, it's possible, if it's under water, suction could suck water into the tank?
Old 02-28-2017, 09:30 AM
Zrock's Avatar
Depending on your machine if it has a exposed air filter you could be splashing up enough water to get into the carb
