TaoTao 125g only starts with remote
Old 03-23-2017, 09:02 PM
Griegojgg's Avatar
Default TaoTao 125g only starts with remote
i recently purchased a taotao 125 for my son. I'm having an issue. It assembled just fine and I cannot get it to start with the ignition switch. I can start it just fine with the key fob provided. I have heard that there is an alarm reset that needs to be done and I cannot find any type of directions for a reset. Any advice or direction is most appreciated.
Old 03-24-2017, 09:19 AM
Zrock's Avatar
when did the 125 start coming with remote start? i thought they were for shut down and alarm only.. Are you holding the brake on when trying to start with key and starter button on handlebar control?
Old 03-24-2017, 12:54 PM
Griegojgg's Avatar
this a 2016 model. The fob is an alarm shutdown as well as remote start. I have tried holding the foot brake and nothing from the ignition switch. It is weird. I have talked to someone about an Alarm reset could be the issue. But I'm not sure how to do that.
Old 03-24-2017, 02:06 PM
Zrock's Avatar
hmm id better go out and check mine as it was a 2016...
As in your other post if the brake light is not coming on when trying to manually start then their is a lose or bad connection in your brake light circuit.
Old 03-24-2017, 02:54 PM
Griegojgg's Avatar
Thank you for the feedback I will check the connections this evening.
